sri 99 accord lx
My sri came with 2 brackets one flat and one L shaped. I assume these are some type of universal mounting for the filter end of it. What is the best set up for this end.I cant find any good pictures of one installed that show this.
RE: sri 99 accord lx
bump
I didn't use either one of the brackets. I saved them in my garage for a while. After I finally threw them out, I saw a pic of an SRI that had the brackets installed. From what I remember, the brackets were attached to the front of wheel well. They served the purpose of supporting the SRI pipe. My pipe didn't really seem to need any support. I just cut a portion of the extra tubing that came with the SRI and put it over the AC line to prevent rubbing.
I used one bracket for now. This one needs some support at the air filter end. I work in a shop where we do alot if aluminum work so Im going to make something similar to what K&N does. Something with a 3 inchhole for the tube and then mount it either to the inner fender or where the old air box was. Might help block some engine heatalso.
