SRS codes
Sent wife in to mech to have SRS light code checked out. Came up with 41 and 77. Can't seem to find any info on these codes. If it is something like a seatbelt switch or circut connection problem I know I can fix most problems. Any insight to this would be appreciated.
what year, make, model, etc...?
03 Honda Pilot ex-l
Sorry, tired last night. Again, codes were 41 and 77. with SRS light on.
I looked in my 03 Acura MDX manual and found 41 is a fault in the LF impact sensor. Any accidents or work in that area?
I could not find a code 77. Acura code are 4 digit code, so the 41 code had three variant 41-1x, 2x, 3x. Each of these is a variation of LF impact sensor fault. The x is a constant number related to SRS manufacturer. Note, this info was based on use of a Honda HDS. There was no mention of manual codes, but others have found that manual codes can be extracted. See following link. DIY: SRS Codes and reading them. - Club RSX Message Board Forum would be interested to hear how you got your codes and any followup w/ the above links. good luck |
