SRS light
The SRS light is on in my 2000 Accord. I looked up all the past posts on the forum and found the reset fix but I have a little problem. The fix says to unplug the yellow plug from the back of the drivers side fuse panel. Well, there's 2 of them. One is just dangling there and I can't find a slot where it would plug in. There is one that looks right, but it looks like the Karr anti theft gizmo has a wire going in it. If this one is supposed to be plugged in, is that maybe the reason the light is on? It is sort of squarish and the other yellow plug is a little more rectangular shaped. Any suggestions would be appreciated.
RE: SRS light
The yellow plug you are looking for has 2 wires going to it and IS NOT connected to anything. There might be a 'holder' for it but there will be no terminals in the 'holder'.
I'm guessing you know the reset procedure, with the jumper wire? Best to have a helper cycle the key and watch the light,while someone else works the jumper wire. |
RE: SRS light
Thanks....I did find a "holder" without any terminals. I guess the plug fell out. Thanks for the info, exactly what I was looking for.
