SRS lights up on my gauge cluster
I picked up a steering wheel for my 95 Coupe EX from a local yard. Wheel only my airbag was fine. I replace the wheel and plug in all connections. When I went to reconnect the negative battery terminal and fire the car the "SRS" light came on the speedo cluster.
Do I need to flash the computer? By the way I picked up the steering wheel for $10 WOW.......And after some cleaning it was in great condition. |
RE: SRS lights up on my gauge cluster
Short the service connector under the glove box. Look at CEL instructions on http://www.dhost.info/accordinfo/
The SRS codes are a main code and a sub code, ie 1-4. Find out what the code is. To clear the code, you have to find the service connector in the dummy plug near the fuse box (drivers side). It is a yellow wrapped wire harness. You have to short the connector, then unplug it, then short it again at the appropriate time. That site I linked above has a shop manual for a 94 accord, so download the SRS. More detailed instructions are in there. |
OMG...........Thank you very much. :D
Hi, I have the same problem on my 2000 Accord EX (4Cyl). Tried fixing at dealership and not successfull. Any suggestion on how to fix or clear SRS light. Thx...
| All times are GMT -5. The time now is 03:52 AM. |
