-   -   Suspension help needed... (https://www.hondaaccordforum.com/forum/general-tech-help-7/suspension-help-needed-40413/)
rgungher01 May 29, 2011 11:41 PM
1999 Accord dx 128K
I'm replacing the cv axle on my accord and ran into some problems. I got the dreaded axle nut off with a large bar, but i cannot get the lower control arm(ball joint) nut off. Its rusty and will not budge. Is there a way to replace the axle while keeping the lower ball joint together. Or can I apply pressure up or down to the assembly to make the lower control arm bolt easier to get off?
Thanks.
WheelBrokerAng May 30, 2011 12:29 AM
Did you penetrate that nut with lots of penetrating oil and let it sit awhile?
rgungher01 May 30, 2011 10:19 AM
Pb Blaster overnight and hitting it with a hammer got it loose, and I just finished replacing the cv axle. No more clicking cv joint...Thanks
