Tachometer Quits - Can Novice Determine Why?
Old May 11, 2009 | 10:18 AM
19962door's Avatar
Smile Tachometer Quits - Can Novice Determine Why?
My tachometer decided to up and leave, no reason given.
According to prior posts re this problem, the connection inside the distributor might be loose. Is this something I can/should check myself, or do I need specialized tools or knowledge?
Thanks in advance - knowledge is power, especially when it comes to fixing your car.
Robert
Old May 11, 2009 | 11:45 AM
First, check for loose/dirty/corroded pins in the wiring harness plug outside of the distributor.
Take off the distributor cap, rotor, & the spark shield (#5). Check for loose wires on the ignitor (#7).
Old May 11, 2009 | 12:21 PM
19962door's Avatar
Arrow Wiring harness plug
Not sure exactly what I'm looking for here - i.e. "the wiring harness plug outside of the distributor." Where on your diagram is this located?
Thanks,
Robert
Old May 11, 2009 | 02:18 PM
I was talking about the multi-wire plugs just outside of the distributor, where the car's wiring harness plugs into the distributor. The body of the distributor is #4, those plugs are kinda visible at the top-right of that part.
It might even be one or more wires cut or torn in that neighborhood?
If that doesn't solve the problem, then go inside the distributor to check the connections at the ignitor.
Then to check further, the wires have to go from there into the dashboard & to the back of the instrument cluster. If you're unlucky, there's a break in the wiring somewhere (anywhere) in-between.
Sgt.Mason.Willis
Apr 30, 2011 09:53 PM
avtuvy
Oct 26, 2009 08:16 AM
tom15425
Jan 8, 2006 04:09 AM
