-   -   Tensioners (https://www.hondaaccordforum.com/forum/general-tech-help-7/tensioners-9366/)
jstehle May 4, 2007 11:39 PM
Tensioners
Hello is it neccessary to change the two tensioners when you replace the timing belt? Or can you just use the old ones. Thanks
hondadude May 5, 2007 01:02 AM
RE: Tensioners
They will usually make it to the second T-belt change.
You can spin them slowlywhile off and feel for a rough spot; also the seals can be gently removed and some fresh grease smeared into the bearing.
