Sponsored by:
Sponsored by:
Threw 2 codes
Old 06-14-2015, 04:28 PM
Devilgreeneyes's Avatar
Default Threw 2 codes
My 2006 Accord EX 2.4L thew P 2185 engine coolant temp sensor 2 circuit high and 61-1 ABS Battery Voltage malfunction. The guy at advance auto said he doesn't know what those codes mean and told me to go to the dealer.
Old 06-14-2015, 08:22 PM
Make sure battery is good and battery connections are clean/secure. Low battery voltage could cause ABS 61.
P2185 is an electrical fault in the Engine Coolant Sensor 2 electrical circuit; faulty sensor, connector, wiring fault, or PCM fault.
Suggest first disconnecting, cleaning electrical contacts (sensor and connector), and reconnecting sensor 2. Sensor is lower driver's side of radiator. Splash shield must be removed.
Next check sensor 2 resistance w/ connector removed. If open or short circuit, problem is the sensor.
If sensor checks OK (finite resistance of a few Kohms at cool temperature), then a wiring/connector fault must be investigated.
If wiring is good, the PCM is problem.
serstylz2
07-20-2012 06:03 AM
Dracco
12-27-2010 07:41 PM
wagon_sc
04-21-2009 02:03 PM
JKobielusz
08-06-2008 06:50 PM
ikethegreat
04-11-2008 10:29 AM
Quick Reply: Threw 2 codes
