Throttle
Here's my problem....when i first start my car in the morning its fine you know it idels alittle high like 2100....and once i hit the gas...my cars rpm's start to just from like 1500 to 2100 for awhile...now im thinking its the throttle position sensor...but not sure...so help me out
another problem is that when i turn right...there is a strange noise from the left axle....i just replaced the axles when i got a new tranny...its more of a clucking sound? any suggestions [IMG]local://upfiles/14604/E7F87EDA170A4538A0CDB185EA5F64DF.jpg[/IMG] [IMG]local://upfiles/14604/044A78FEB2F04CD79B6106B85F72BA24.jpg[/IMG] |
RE: Throttle
Put your vehicle information into your signature so we know exactly what motor/tranny etc we're working with...
RE: Throttle
alright well there it is...so what do ya think....could it be the map sensor cuz when i unplug it ...it like resets itself but it will come back after a little bit
RE: Throttle
Under our DIY section there is a post on surging idle that may help. A quick clean on the FITV may yeild some good results.
As for the clunking sound can you be a bit more specific about when it happens vs. when it doesn't? |
RE: Throttle
well i dontk now what the FITV means...sorry let me know and the clunking sounds only when im making a right turn...and maybe a little when i turn left but not as bad
RE: Throttle
ORIGINAL: 94CFaccord another problem is that when i turn right...there is a strange noise from the left axle....i just replaced the axles when i got a new tranny...its more of a clucking sound? any suggestions |
RE: Throttle
ORIGINAL: JohnL ORIGINAL: 94CFaccord another problem is that when i turn right...there is a strange noise from the left axle....i just replaced the axles when i got a new tranny...its more of a clucking sound? any suggestions Is it a one time loud like "CLUNK" or does it repeatedly do it? |
RE: Throttle
well its a repeated clunk till the wheel is straight and then nothing...its only when im turning right its loud
RE: Throttle
Time to replace the right side CV joint...?
