Timing Belt to Gear Conversion???
I am a former gearhead of AMC and International engines. Both of those have timing gears and not belts...your maintenance intervals are infintely longer with gears. I know on some other vehicles, there are conversion kits available. Has anyone ever heard of a conversion kit for my 2001 Accord EX V6?
Once again...timing belt to gear (driven) conversion. Any help and info would be appreciated. Thanks, |
RE: Timing Belt to Gear Conversion???
I've never heard of it, but it would be great if they had one. The 2003-2007 4cyl models had timing chains instead of belts, but the v6 still has a belt. I am unaware of the 2008 models as to whether they use belts or chains.
Aren't gears for pushrod engines? I've never seen an overhead cam engine with a timing gear.
ORIGINAL: falkore24 Aren't gears for pushrod engines? I've never seen an overhead cam engine with a timing gear. |
Not possible unless you got someone to make you a custom cam, crank gear, chain, then figure out how all the sensors that read off the crank would get their input.
