Torn door seal replacement
Hey, how's it going. I want to know if you guys know where I can find door seals and info on replacing them. I have an 86. It's doors wrap around onto the top of the car unlike a lot of other vehicles. Anyway the top seal tore, or was torn when I bought the car. There's no water in interior, but every so often the door freezes solid. I have thought about using epoxy and rubber cement to put it back together, but I'm worried about that causing more problems. Any ideas, tips, or suggestions would be helpful.
[IMG]local://upfiles/11240/79B4140B11AA4D2091BAEE156E260C2C.jpg[/IMG] [IMG]local://upfiles/11240/60956A41B2F3485BB88F9AF8C8EC6D2D.jpg[/IMG] |
RE: Torn door seal replacement
I'm sure you can buy replacement bulk door seal and either replace entire seal or splice in a new piece. Check online w/ google and ebay.
Honda parts should also furnish the entire door seal. Another solution would be to go to a junkyard and look for some material from a wrecked vehicle. This is probably similar seal for many model years. good luck |
