torque questions
Ok guys, these are the tools I plan to use to install my spark plugs. How much torque should I add, for the spark plug tool swivel?
http://i41.photobucket.com/albums/e2...K/DSC01182.jpg |
do not waste you time torquing the plugs,, i have installed probable thousands of plugs and never used a torque wrench......put a bit of anti seize on the threads, use a hand ratchet ,once they are snug just go about 1/8 turn more and that;s it
But but but:(, I have a torque wrench, so I would like to use it. Thanks anyway DH.
but but but ...ok... :-)......if you insist ,, torque spec is 13 ft lb
Hello Tool Man
1 Attachment(s)
Originally Posted by deserthonda
(Post 205716)
|Hey My Friend...I liked your answer the bestest....Desert |Hey and NightHawk...better get your torque tool torqu checked, bet it never has been done since it was new...:eek: WheelBrokerAng |
Thanks a lot guys. What I wanted to know is how much should I add for the spark plug tool. I guess it's not that critical. I'm going with 15 ftlbs.
I have just put 6 spark plugs ( Ngk laser iridium izfr6k11 ) pre gaped at 0.044.
I have suspicion that spark plug is hitting piston . Is that possible ? I torued them to 18-20 ftlbs. Please watch the video. I use 5w20 max life high mileage volvoline synthetic blend oil. Is it possible I just should shift to 5w30 and this voice will be normal? Today temperature outside was 50 degree degree F. Is it possible the viscosity if oil I am using is not enough for the power new spark plugs are giving ? If oil viscosity increase is the solution, what grade I should use 10w40 is good ? |
Originally Posted by EXV6NIGHTHAWK
(Post 205762)
Originally Posted by hemantrhtk
(Post 314196)
| All times are GMT -5. The time now is 09:11 AM. |
