Tranny Issues
Well driving in third gear or down shifting to third gear the the rpms rev up and down between 3k-4k the car has 145k on it and its a manaul tranny. Any ideas much apprectiated 1999 accord ex thanks
Clutch plate worn out seems likely.
good luck |
What am I looking at as far as cost to repair?
^^^clutch plate worn out means clutch is slipping, which is a disconnect, under load, between engine rpm and road speed.
Originally Posted by boosted89gt
(Post 261099)
Well driving in third gear or down shifting to third gear the the rpms rev up and down between 3k-4k ... and its a manaul tranny.
So to tell if the clutch is slipping do this, using the 2nd gear test : write down on scratch pad how many rpms = 20 mph, exactly. find an isolated hill, head up it and floor it flat out, 2nd gear, starting at ~15 mph keep your blinking foot in it! how many rpms = 40 mph? how many rpms = 60 mph? so are the 20 / 40 / 60 mph all proportionate to rpm's? If so your clutch isn't slipping. If your clutch is slipping your rpms will go to the moon w/o your speed increasing. You can also tell if this happens, in real time, by your own statement of: "Oh fook!" hope this helps. then get a 6-pack and post up results |
