-   -   trans fluid in o2 sensor (https://www.hondaaccordforum.com/forum/general-tech-help-7/trans-fluid-o2-sensor-11497/)
Rockwell Aug 3, 2007 05:29 PM
90 accord EX Automatic.160,000 miles.Changing my o2 sensor last weekend because I had a code 43. When I unpluged theold sensor I noticed red fluid in the plug. I assume its transmission fluid but I can't see where its coming from. Has anybody had this problem with fluid in the o2 plug. Thanks.
Chiovnidca Aug 3, 2007 05:49 PM
RE: trans fluid in o2 sensor
It's usually from oil leaking from the distributor o-ring or the valve cover gasket. Maje sure to get the leak fixed before installing the o2 or it can quickly be contaminated.
