-   -   Transmission or engine mounts? (https://www.hondaaccordforum.com/forum/general-tech-help-7/transmission-engine-mounts-51140/)
LordAccord Oct 30, 2012 06:55 PM
My 98 Accord EX V6 3.0 sometimes takes a second or two before I can feel the gear shift, or at least that's what I believe it is. When I switch from park to drive, or drive to reverse, a second or two later it will buck or jerk a little bit and I'll hear it do so.
Do revitalizant or any other oils I see marketed in Popular Mechanics for transmission really help make it better? Can anyone attest to that? Thanks
I see one product that says it "reverses wear" and "coats vital transmission parts" and I want to know if that can noticeably effect the transmission.
LordAccord Oct 30, 2012 06:56 PM
Amazon.com: XADO Revitalizant EX120 for automatic transmissions (blister package, syringe 8 ml): Automotive
PAhonda Oct 30, 2012 09:43 PM
The 98-02 V6 transmissions were known to have transmission failures. When was the last time you changed the transmission fluid? What brand of fluid did you use?
LordAccord Oct 31, 2012 11:16 AM
I bought the car in the beginning of July so I haven't changed the fluids yet.
I know it won't help me, but why were the transmissions problematic for that time frame?
poorman212 Oct 31, 2012 12:21 PM
Best write up I've found to date on this issue:
http://www.sonnax.com/system/pdfs/35...pdf?1320330979
Can't say this is "the fix" but someone went thru a ton of testing.
