Transmission Fluid: Mercon, Dexron
My manual recommends Dexron II or Honda ATF transmission fluid, however, I don't think they make Dexron II anymore, or it isn't on the shelfat my local auto parts store. What can be used as a replacement? Mercon V?
RE: Transmission Fluid: Mercon, Dexron
Honda ATF-Z1
if your OE specs called for Dexron II or IIE then the line of transmission fluids that are just standard multi-vehicle ATF's are the new Dexron lines, I.E. Castrol Domestic/Import multi vehicle, or any other brand that says just ATF. Z-1 is good as well, or AMSOIL ATF.
honda wants dex only temporarily though. honda fluid is very good and about $7 a qt.
mine hates Z-1
If you read the back of Advance Auto Brand Mercon V, it specifies that is a replacement for Honda Z-1.
I work for Advance DO NOT use any Advance Tranny fluid in a honda.
ORIGINAL: drummer1279 I work for Advance DO NOT use any Advance Tranny fluid in a honda. |
Im not sure who manufactures and bottles the Advance brand but trust me its not up to par even with the name brand fluids. Ive seen it run through old domestic vehicles and cause problems.
don't be a cheap **BUTT**, use honda OEM parts for the best results expecially in COLD WEATHER as Honda ATF flows better. I can never understand why people buy a car and then want to save money by using the cheapest stuff possible when doing maint.
