transmission problems
[:@] extremley frustraited...... got a 93 accord auto. lost all of the trans. fluid, havent found out where it leaked yet, but the car wouldnt start with no fluid. does it have a fluid level saftey switch. or is it that a different problem.just had trans. built 2 months ago. need help???????????[sm=helpout.gif]
RE: transmission problems help please?
put fluid in till it touched the stick. car still will not start. starter will not engage into flywheel. don't know what to do. Thanks for any advice.
If starter "clicks" but does not engage flywheel, the problem is the starter and not the transmission. A new or rebuilt starter is necessary. Copper contacts can be replaced in the starter solenoid if you're diy. Do a search for plenty of info on procedure.
If starter loads up but flywheel won't turn, the engine may be frozen. Try turning the engine over from the crankshaft pulley bolt w/ a long extension, 19mm deep socket to see if engine is frozen. Brake set, trans in park, turn wrench CCW. good luck |
found out it wasn't the starter. took inspection plate off the bottom, seen the flywheel turning when the starter was engaged. does
this mean its the tourque converter. Thanks for the info. on the starter.This is a great forum. |
| All times are GMT -5. The time now is 05:16 AM. |
