Transmission Slip Help
http://s596.photobucket.com/albums/t...00405-2343.flv
Anyone have any experience with this problem I've never seen a transmission problem where the rpms bounce like this. 2001 Accord Ex 4 cylinder 2.3 L v tec 150,000 miles Email me is you got any ideas |
What is that YELLOW LIGHT?
Originally Posted by hondadude
(Post 200771)
Its been to the mechanic he charged me 400 for a air-fuel sensor and sent me on my way, 5 hours later i took that video. car was fine today brought it back to the mechanic and he had no idea what to do so he just reset the light. the code was p1381 which is a cylinder sensor located in the distributor however the last time this happened to my car i was told it had two codes which were engine misfire and tranny slip. on top of that Im now getting 11 miles to the gallon from 27
P1381 = CYP sensor intermittent
Look for loose/dirty/corroded connections at the wiring harness plugs of the distributor. |
had the same problem if thats a tranny slip. took it to a transmission specialist 3000$ to fix it
