tras problem in d4
I had my trans fix because it wasnt engaging in first when i put my car in d4 but after rebuild once again is doing the same thing. If i put reverse or 2 it works really good. In 2 once going i put the car in d4 and it drives normally until i get to a stop.. :'( any ideas... Is there a solenoid in first gear.
What year are we working on here?
Any stored codes? |
No codes so far... :'( my car is a 99 with a baxa trans on it..4cyl ulev vtec...tnx
When did you get the rebuild? Sounds like a faulty or incomplete rebuild, I would return to the shop and ask them to warranty it. If they give you a hard time then turn up the heat on them.
I did so and it seem to be a problem in the valve body...back to the shop... :-\
