Use Honda ATF after used other brands
Hi all,
My 92 accord AT has had ATF changed every 30k at shop in the past. I don't know the brands the shop used. I've read this forum and decide to use genuine Honda ATF from now. Is there any issues of using genuine product after using third party ATF in Honda engine? Thank you for your advice. Ted |
I think I'd just go ahead & switch to Honda fluid. Maybe 3x drain/fill cycles so "most" of the fluid will be Honda. If the fluid comes out dirty or anything, then certainly 3x cycles.
What was Honda's ATF standard back in 1992? I'm wondering if DW-1 is even the correct ATF for a 1992 Accord.
The 92 owner manual says use DEXRON II Type ATF.
Ted |
Originally Posted by ticktock
(Post 385801)
Ted |
Sorry, I wasn't thinking about what year Honda started using special ATF.
If I had a car which called for Dextron-II, I'd probably use this ATF:
Hi Shipo,
I saw that Valvoline but have been reluctant on it because it's not Dextron II. Hi Jim, don't say sorry. You have been very helpful in the forum for many years. Seeing your response makes me happy already. Thank you both. Ted |
(Post 385810)
Hi Shipo,
(Post 385810)
Hi Shipo,
