Vibration when going 60-70
Old Sep 13, 2012 | 05:57 PM
94ex915's Avatar
Almost A Senior Member
Default Vibration when going 60-70
Alright well I changed the brakes a few days ago and I noticed today that when I go over 60 the steering wheel starts to shake. When I hit about 70 it seems to calm down. This doesn't happen when I'm braking only when driving. I tightened up the lug nuts some more to see if that would fix the problem and it kind of helped. What would my problem be?
Old Sep 13, 2012 | 06:23 PM
94ex915's Avatar
Anyone? I'm thinking of taking it in to get the tires balanced and rotated.
Old Sep 13, 2012 | 06:24 PM
00AccordLX5spd's Avatar
Registered User
You need to get your wheels balanced. Tire shop should be able to do that for $20-$50
Old Sep 13, 2012 | 10:24 PM
94ex915's Avatar
Alright. Got them balanced and rotated and will be testing it on the freeway and will post back after I do.
Old Sep 14, 2012 | 12:42 AM
94ex915's Avatar
Well I just got back and there is still come shaking from the steering wheel but it doesnt seem as bad as it was. Can bad wheel alignment also cause this?
Old Sep 14, 2012 | 06:20 PM
Registered User
Wheels out of balance are the most common cause. I'm not going to say it can't be the alignment though. Does it pull to the right or left? Have you inspected all 4 tires to make sure they are in good shape and no abnormalities? I would assume the shop that balanced the wheels would have inspected them, but I do know the definition of "assume."
Old Sep 14, 2012 | 09:08 PM
94ex915's Avatar
They did inspect the tires and said there was uneven tread on the drivers side in the rear. Not sure on how the alignment works but when I have the wheels straight the steering wheel is kind of to the left.
Old Sep 14, 2012 | 09:47 PM
They should be able to adjust the steering wheel to be straight when the wheels are going straight.
What kind of CV joints did you get? New/Remanufactured? What brand?
Old Sep 15, 2012 | 02:43 PM
94ex915's Avatar
Haven't replaced the CV joints yet.
Old Sep 15, 2012 | 04:01 PM
MysticBlueEX's Avatar
When you take it back to the shop be sure to have someone check the tie rod ends. I haven't needed to replace those on the Honda, but every car that had a bad T-R-E made the steering wheel oscillate left and right at highway speeds.
The car didn't move out of the lane, just the steering wheel moved back and forth just a little bit at like a 30 times a min.
Have the ends checked before you spend the money on an alignment.
