Video: steering makes noise when engine cold and cold weather
Hi,
I have a 2003 Accord 6-speed v6 coupe. Video of my issue is here: only happens when the engine is cold. after it warms up it doesn't happen at all. Thanks for the help. |
Probably due to air is entering the power steering pump through the inlet joint O-ring.
DIY Power Steering Pump O-Ring TSB - Drive Accord Honda Forums |
mine did the same. Honda dealer wanted 750.00 to fix many things. There is an updated red o-ring at the inlet fitting on the pump. .89 cents and 5 minutes to change. Dealers suck!!!
A LOT of people got screwed for pumps with this issue. Luckily, I knew about the o-ring before my pump started screaming one cold morning.
Low PS fluid level will also cause this problem. Make sure fluid level is good and no leaks.
good luck |
