VTEC means? 16v?Y/N.
What does VTEC stand for.
Are they 16v? |
RE: VTEC means? 16v?Y/N.
VTEC: Variable Valve Timing and Lift Electronic Control and just because it's a vtec doesn't mean it's 16 valve I don't believe, it simply means that there is a change that the engine goes through in order to give you a "power band" of sorts and keep the power from leveling out/dropping off at higher rpm's
| All times are GMT -5. The time now is 07:44 AM. |
