VTEC Timing Belt
I have a 04 Accord 3.0 VTEC Anyone have a write up on the timing belt replacement?
Thanks |
I don't think there is a DIY on here, but you can search the forum, because I am not sure.
I think that the ericthecarguy website has one for sale for around $10. |
I thought the '03 and after Accords had timing CHAINS. Maybe I'm mistaken.
4 cyl yes....the 6cyl still use a belt.
This is one on an Acura TL, basically the same engine. I would not do the job without a shop manual though. The how-to doesn't give you torque specs etc. I would also change the water pump, tensioner, idler pulley, and adjuster pulley. Good luck.
http://tl.acurazine.com/forums/showthread.php?t=695821 |
