Warning??
i HAVE A 97 ACCORD COUPE/AUTO V-6. SOMETIMES AFTER IT IS WARMED UP, THE DASH LIGHTS WILL STUDDER/OR FLASH WHEN STARTING. I CHECKED THE BATTERY POSTS YESTERDAY MORNING AND THE POSITIVE NEEDED CLEANING, AND SO I DID. THEN I HAD THE BATTERY CHECKED AND THE CRANKING AMPS WERE A LITTLE LOW. AM I ON THE RIGHT TRACK HERE??
Yes. A bad ground is one of the things that would cause the issue you are describing.
ground location
where exactly would I find that?
