Washer motor
Seems like things break at the same time. The washer motor has quit working- not the fuse. Can anyone tell me how to get access to it so I can test/replace it? Thanks
Looks like you might have to remove the plastic inner-fender liner at the left-front wheel?
http://www.hondaautomotiveparts.com/...3sv401_b15.png |
Okay, never done that. Is it obvious or are there any tips you can give me on removing it?
I haven't done it, but you'll probably have to look for all the screws & all the plastic push-pins.
The spooner link from the Online Manuals thread in the main DIY section has a 94 shop manual that you can download. That should show you all the items that you will need to remove to replace it.
| All times are GMT -5. The time now is 02:30 AM. |
