Water leak in read floor pan
I have a 95 Accord and when it rains I get water in my rear floor pan on the driver's side only. When I open the driver's side front door you can see water on the small plastic strip on the bottom of the door frame but the water only runs into the back floor pan. Any help or advice?
RE: Water leak in read floor pan
Check all of your weather stripping around those doors to see if there is a loose area that the water is flowing in from...
WheelBrokerAng [sm=smokin.gif] |
if u got a moon roof i would chk to make sure the drains are not plugged ..
