-   -   water leak under passenger seat Accord96 (https://www.hondaaccordforum.com/forum/general-tech-help-7/water-leak-under-passenger-seat-accord96-25470/)
jjandshi May 18, 2009 10:28 PM
Water leaks around the plug indicated by the arrow. Thanks.
http://files.filefront.com/leak+wate.../fileinfo.html
jjandshi May 18, 2009 10:34 PM
Sorry the picture is here
1 Attachment(s)
http://postdownload.filefront.com/13...8078111bdd630c
JimBlake May 19, 2009 07:04 AM
I think you'll just have to clean it up real good & seal with caulking.
TexasHonda May 19, 2009 12:01 PM
Is water leaking in from around the plug or is that where water drops from above?
If from above, the evaporator case is filling w/ condensate from AC use and running over. Drain line repair or evaporator clean-out needed.
JimBlake May 19, 2009 12:16 PM
Tex, that's the left-side rear seat; looking in from the left-rear door. Water would have to run from the dashboard, cross over the center exhaust tunnel, then jump up to that place which is at a higher level then the front footwells.
