water pump job plus oil in plugs
I've got the new water pump in, all new seals, new tensioners and I'm ready to do the belts. I did notice that one spark plug had oil in it. Just wanted your opinion should I replace the bottom seals now or just try new uppers and hope that fixes it? Do the lower seals go bad all that often? Thanks in advance!
RE: water pump job plus oil in plugs
while you have that much of the engine broken down it would be a good idea to go ahead and do all that as well. better safe than sorry. those seals should be replaced every time you put on a new valve cover set along with the uppers, it all comes in a kit.
That's what I thought as well. Thanks for the advice!
no problem
