andrew520 |
05-30-2018 10:25 AM |
Weird AC Problem, Control button activates IAC, One Fan, No power to others
1994 Accord EX. Verified proper freon charge amount. When the AC button is on, the passenger side cooling fan activates and the IAC bumps the idle up but does not send power to the driver side cooling fan, nor the compressor clutch. I've jumped the PSI switch, the T-Stat, and verified the clutch and driver side fan does engage with 12V supplied directly from the battery. Swapped both relays at the radiator with NEW parts, and checked ALL fuses inside and under the hood. All were good. AC was working and all of a sudden stopped.
Any help greatly appreciated. Also I checked wiring the best I could and don't see any visible damage.
