Weird noise from alternator ?
Old Jul 29, 2013 | 12:15 PM
justing920's Avatar
Default Weird noise from alternator ?
I have a 94 accord sedan vtec with 192k nd everytime i start the car it makes this weird noise like a buzzing then a screch it sounds like its coming from the alternator. Or somwhere around there it does it till the car warms up once its warm it goes away I have no idea what it is but its pretty loud any idea!
Old Jul 29, 2013 | 01:43 PM
When if ever were the belts replaced if you know?
Also , does it maybe sound like a bearing noise. ?
Old Jul 29, 2013 | 06:53 PM
justing920's Avatar
I replaced the belts about 2 moths ago they were shredded nd sort of it makes some other kind if noise. While its warming. Up also but its been doin that since. I got the car 2 yrs ago
Old Jul 30, 2013 | 05:56 PM
Check the tension on the belt.
Are any warning lights on - ABS ?
Old Aug 2, 2013 | 05:56 PM
justing920's Avatar
Yes the abs light nd cel
Old Aug 2, 2013 | 07:09 PM
00AccordLX5spd's Avatar
Registered User
Have you had the cel code read?
Old Aug 2, 2013 | 08:31 PM
justing920's Avatar
No i havent how do i so that
Old Aug 3, 2013 | 11:59 AM
Ok, here is where I'm at. The noise is not the alt, instead it is the ABS pump. A least my "guess" at this point.
To get the codes - ECU, TCU, SRS or ABS - jump the service connector (pass side under/behind glove box) and turn the key to on and count the flashes from the lights (again - CEL, D4, ABS or SRS).
Let us know what code you get from which light and we can go from there. I'll guess you will get an ABS pump over run code from the ABS light.
Old Aug 3, 2013 | 01:02 PM
justing920's Avatar
Just did it got cel code-93
D4code got -15
Abs got-13
Old Aug 3, 2013 | 01:26 PM
Recheck the CEL code - 93 does not come up. If you can take a video of the lights/flashes we might be able to help (long vs. short)
ABS - if it is 1-3 that is a high pressure leakage. I would start, again just me, by double checking the fluid level in the ABS unit. Then bleed the ABS unit.
D4- a 15 is for the mainshaft sensor. I'd pull the sensor, clean the end of it and re-install.
Clear the codes - pull the fuse from the under hood fuse box to the ECU. Give it ~20 seconds or so and re-install fuse.
Drive the car for a bit and recheck codes if any come back.
