what the heck
just checked my dipstick and oil level in the accord and it was barely touching the tip of the stick[:@] there are no oil leaks, no smoke from my exhaust, and performance is great...what gives? why is it empty on oil now? luckily i checked the oil level today and the engine didnt go out on me...gonna go buy some quarts to fill her up...maybe adding lucas will help too..any suggestions appreciated...
RE: what the hell
im so stupid!!lol i waste all my money on my cars!!!!lol[&:]
RE: what the hell
Whens the last time you checked it?
RE: what the hell
instead of adding 2-3 qts ,why not do an oil and filter job, then you should monitor it closely to see what is going on ..
RE: what the hell
Check inside of you intake duct downstream of PCV air outlet (goes to valve cover). If you see lots of oil in the duct, the PCV or PCV hose is blocked and oil vapor is being pushed into the engine. Clean PCV hose and replace valve will fix.
good luck |
RE: what the hell
lmao that last message my gf wrote because she thinks all my money goes into my cars ..i accidently left this open and she found it...therefore that messege
RE: what the hell
ok now my oil is overfilled...stupid. i was on a leveled surface when i checked it...but once i poured two quarts it was way over full...now i need to drain it i suppose...
RE: what the hell
Take DH's advice and just do a regular change then keep an eye on it.
