what parts it get for 5th gen brake swap
hey i heard a while ago that you could use older odyssey front brakes to swap a 5th gen accords dumb hub over rotor design for a rotor over hub to make doing rotors alot easier and was wondering if thats true and if not what do i need to do it. my car has over 300k miles on it and still runs great and i want to see how far i can get the car to go but im not really trying to keep replacing to front rotors how the set-up is now because it takes way to long.
I did this swap on my 95 accord. You need the front hubs from a 98/99 Acura CL and the 98/99 Acura CL rotors. The bearing, caliper, and pads are the ones you use for your accord.
Here is a link from the DIY section on how to do this.
https://www.hondaaccordforum.com/for...nversion-3151/
You'll have to do some research. You'll need to replace the hub and rotor, but you'll have to do some research. The first item is to see if the steering knuckle has the same OEM part number for your accord wagon and the 98/99 CL, because you'll need the new hub/bearing to bolt into the knuckle.
