What's this?
There's a hose dropping from under my 2012 Honda accord I believe it's from the ac but I just want to be sure
https://cimg8.ibsrv.net/gimg/www.hon...57af6d8e6b.jpg |
Is that a welded nut and a bolt threaded through? It is hard to tell from the picture.
My best guess is that is some kind of rubber bushing for the sub-frame of the car or maybe a rubber dampener to prevent vibration of a component. You'll have to look on the other side to see what is connected. I don't think it is a/c related. |
Welcome to forum.
Can't tell either, looks like there is a drip of water visible from inside. What is your interest / problem / question ... or is it a curious identification question only? AC units generate water when cooling the air so water drips out 'fast' in properly operating units, more so in humid environments. |
Here's the heater unit under the middle of the dashboard/console.
The drain hose is #22. It looks like the very bottom of that hose should poke out from the underside of the floor, just a bit towards the right side of the car. https://cimg1.ibsrv.net/gimg/www.hon...985b11800e.gif |
Awesome thank you that diagram helped alot thank you
| All times are GMT -5. The time now is 01:01 AM. |
