when is it time to change the timing belt?
just wondering because i have 129000 miles and its never been replaced
RE: when is it time to change the timing belt?
Use the search function. or just browse the DIY section.
You need to replace yours. |
Here's what happens when timing belt breaks. Although this didn't occur due to a timing belt breakage, it had same effect; crankshaft and camshaft are not in sync and pistons hit the valves. I was lucky (relatively) that pistons were not damaged.
regards [IMG]local://upfiles/8174/EDCF2B6F955D48E18383A294F055565C.jpg[/IMG] |
you should do it ASAP,,
ya i kinda thought so, my mom said she was gonna wait till it breaks then replace it (along with the enginelol) how much should it cost. ive heard its not cheap.
Replacing the belt is way cheaper than buying & installing a new engine...
Between $400 and $800 (it all depends on what part of the country you live in.) Mine cost $450 for the timing belt, water pump, seals, and outer belts. I have been told that was a very good price.
Use genuine Honda parts. Have either a Honda Certified shop (likely cheaper) do the work or a Honda Dealership (more expensive) do the work. Look in the Phone book for Honda certified shops and dealers in your area. Call them all and get price quotes. |
