where is the blower motor resistor 2003
Ok, the blower motor quit working. It works when plugged directly to a 12 volt battery. I took it to the dealership and the service writing underhandedly told me it was the resistor. He would not give me any more information. I have the blower motor out. Where is the resistor? Thanks.
RE: where is the blower motor resistor 2003
I don't know specifically on that model, but resistor is usually on the blower or evaporator housing nearby. Relatively large and hard to miss. Follow connector from blower backwards.
good luck |
In this pic it is number 11 I'm fairly certain it is in the top of the ducting to the drivers side of the blower unit.
http://www.hondaautomotiveparts.com/...SDA0_B1720.gif |
Thanks, I found it to the back left of the blower attached with 2 screws to the firewall on the inside. Changed the resistor and now I have AC again.
Sorry to pull up such an old thread...
but may ask about the problem that you had... cuz my AC is not working and i wonder if that is the same case as yours was... in addition, someone told me it could be the Blower Motor Resistor that is causing my problem?? |
Does the blower work at any speed or not at all? Did the blower quit working suddenly or did you gradually lose 1 fan speed after another?
Try thumping the blower module w/ your hand. If the blower starts and runs, the blower brushes are worn out. They are not replaceable and a new blower motor is necessary. good luck |
i have suddenly lost the blower... it stopped working completely...
well, the thing is i dont know where is the blower??? someone told me its under the dashboard beside the glove box!!! is there any guide of how to reach there??? i have never unscrew any screw in the car... i want to do so but in the right way... so can anyone help a little bit more? |
Honda Dude gets the #1 star with his always great pictures of " Where Its At ";)
Thanks HondaDude .... WheelBrokerAng :) |
ORIGINAL: BU50 i have suddenly lost the blower... it stopped working completely... well, the thing is i dont know where is the blower??? someone told me its under the dashboard beside the glove box!!! is there any guide of how to reach there??? i have never unscrew any screw in the car... i want to do so but in the right way... so can anyone help a little bit more? And look at the pictures before you posted..;) |
I will try my best with the blower n with keeping you guys updated
