where to buy blank plug replacement for the dash
2 Attachment(s)
does anyone know where i can buy a replacement blank plug becuase i would like to install a toggle switch in the empty slot beside the main cruise switch and the traction control system switch and if i want to remove the toggle i don't want a blank plug with a hole in the middle of it. thanks
(in the images it is the blank plug on the left) |
At the hondapartsnow.com site, the part is under electrical/exhaust/heater/fuel, then switch. It is part number 9. Shipping is usually too expensive, and you will likely save money by buying at the dealership.
Just make sure you get the one that is the right color for your interior. Use the color code. It should be on a sticker inside the driver's door jamb. |
Thank you so much just what I was looking for
or try a junk yard, a little black plastic paint. Then a rocker type switch and it would "blend" in with the others....just my two cents.
