Where are the motor mounts
Located on a 1993 accord lx. Front, rear, and are there any others?
RE: Where are the motor mounts
I think there's 4.
Front, towards the radiator. Rear, under the firewall. Front of engine, near drive belts. Tranny, maybe blocked by battery? |
This pic might help you, the rear subframe mount is different if 5spd or Auto.
The most common motor mount problem for your year is the front subframe mount/to the trans,#15; the rubber at the top of that "dogbone" cracks out. If you have an Auto trans #4 mount it is vacum actuated and there is also a little linkage on the back side that sometimes comes loose http://www.hondaautomotiveparts.com/...13SM40_B47.gif |
| All times are GMT -5. The time now is 07:51 AM. |
