Where is my brake booster at??
I've looked around the forums and the internet but cant get a straight answer here.
All I'd like to know is where my brake booster cable is??? (i'm seafoaming my car so...) I hear its just the vacuum cable on the driver side near the firewall blah blah blah, still there are lots of cables in that area haha. |
It is the unit between the master cylinder and firewall on most cars.
I need to know where the vacuum cable is, that is what side to disconnect and whatnot. A picture would be most appreciated. Your description is still fairly vague, keep in mind i dont know what the booster even is. let alone what it looks like.
It's the big round thing behind the master cylinder, #1 here.
http://www.hondaautomotiveparts.com/...4sdn01_b24.png I think the windshield & cowling overhang forward, so you have to look back underneath to see it. Only the reservoir & the end of the master cylinder stick out beyond the cowling. |
Your vacuum hose is #6. As far as disconnecting it, what are you planning to do? Seafoam you could disconnect either end, maybe the engine-end is easier to disconnect. But then you'll want to find another hose to put in it's place & put the seafoam in there.
this is exactly what i needed Jim! thanks. All i plan to do is seafoam the thing.
where do you get these diagrams? i could probably use this site quite often. |
www dot hondaautomotiveparts dot com
click PARTS put in your car's information I think the pictures are from Honda's electronic parts catalog, 'cause several on-line dealer parts departments have the same pictures. |
I need help finding my vacuum hose on my 2010 Accord V6?
can you provide a diagram on where it might be located? My purpose is to clean m intake valves using CRC intake valve cleaner. Thanks, |
