-   -   Why consuming more gas ? Help Please (https://www.hondaaccordforum.com/forum/general-tech-help-7/why-consuming-more-gas-help-please-43344/)
03Accordcupz Oct 13, 2011 05:35 PM
Hey guys! I own a 2003 Honda Accord V6 Couple with 180,000KM on it. I have noticed the past month that my car has been consuming a lot more gas than usual and has a bit of a shake when the car is at idle (only in park position can’t feel it a drive gear)
Car had a full tune up done at 165,000KM (NGK spark plugs, filters, Timing belt, water pump, coolant flush)
Had the Transmission rebuilt at 175,000KM (Not a good 2 months, hear this is a common occurrence)
Someone at work told me to see to check my O2 sensor? I have no Check engine light on my dash. Only light is that stupid low washer fluid light that just won’t go away hahah
Any suggestions?
Jamesbp88 Oct 15, 2011 12:02 AM
Your O2 could be going bad without a check engine light on, generally if it's bad enough to cause a rough idle you should have some sort of light on. The shaking could just be bad engine/trans mounts. The O2 sesnsor should be checked manually for voltage readings. If you're not too familair with this type of work I would reccomend paying 100 bucks to have a shop diagnose the problem for you.
TexasHonda Oct 15, 2011 07:47 AM
Also check fuel lines for leaks. We've seen a few cases of fuel lines leaking due to road salt corrosion.
