Windshield Wipers Not Working
I have a Honda Accord 2005. It has a auto-transmission. One day I started my car and tried turning on the wipers. It was dead. It did not respond to any of the controls. The nozzle does spray. First thing I did was I checked the fuses and relays. All worked. I replace them with a spare one and still did not work. I also realized that it was making a click sound every time I attempted to turn them on. I removed the front piece over the wiper motor to make sure the cables were in and they were. Any ideas?
Get a spool of wire & some end-terminals. If you can find blade-terminals that connect to that plug, that'll be handy. Or alligator-clips.
Make 2 wires, one to connect the proper terminal to a solid metal ground somewhere nearby. The other one long enough to go from the battery (+) post over to that plug on the motor. If you're ambitious, you can put a switch in the (+) wire; otherwise you have to connect & disconnect it.
I tested the motor and it was dead. So, I pick up a new one and installed it and it worked. The only thing was that I installed the pattern wrong, the wiper was going down then up and stop at the middle. So I disassembled it, fixed the order then put it back together. When I tested it, it did the same thing as the first time with the old motor. No movement, and a click.
Don't know if this will make a difference in your situation; but, refer to step #17 in the following Honda TSB regarding tightening the the wiper motor center nut just enough to seat its lock washer.
In addition to making sure the 5P connector clicks into position.
Honda TSB 08-043
Honda TSB 08-043
