Smaller Size Tires
Old 10-23-2008, 05:14 AM
cd75bus
Default Smaller Size Tires
Hello out there, being a cheap kind of guy, I got a deal on four 14" snow tires for my 2002 Accord (4 cyl) and since there are 15" tires on there now, someone is telling me I'm gonna have engine, computer, tranny (auto) problems. Other than speedo and milage reading being a little off, any had experiance with this ?. Any help is appreciated. Thanks
Chuck
Old 10-23-2008, 06:35 AM
Default RE: Smaller Size Tires
Never heard of this, and know a ton of people running different than stock rims and tires including myself. I wouldnt worry about it.
Old 10-23-2008, 07:21 AM
With a 2002, you MIGHT(?) have brake clearance problems. I think maybe 15 inch was the smallest stock size?
Old 10-24-2008, 11:35 PM
Please make sure that you post your nexts posts in the correct forums...I moved you to this one..Welcome to the HAF...
Old 10-25-2008, 01:53 PM
finch13's Avatar
ORIGINAL: JimBlake
Nope. I'm running the 14" steelies from my 1995 (nicer tires) and have no issues whatsoever. I have Integra sized tires so my speedo is off by a bit, but as long as the rolling diameter of the tires you bought are somewhat close to what you currently have they should be fine.
Go to miata.net/garage/tirecalc.html to compare the two.
Old 10-27-2008, 06:54 AM
As long as they fit over the brakes, its OK. Your ABS might have problems, ONLY if you have different sizes on different corners.
Old 10-27-2008, 02:16 PM
MikeT's Avatar
I think it all comes down to the circumference difference between the tires. If there is a difference then you will see a speedo difference. I doubt you will have any trans issues or ABS issues. Ireally can't see how there could be any problems at all unless the brake calipers won't clear....
Old 10-27-2008, 02:41 PM
streetwise's Avatar
Well I hope you got some 14" wheels for those tires cause you sure cant put 14" tires on a 15" wheel.
For a quick test just stand one of the snow tires next to the 15" thats on there now, if it is within
about a half inch of being as tall(profile) you wont notice any problem.
ranck42
02-24-2010 11:11 AM
91exwagon
08-10-2009 04:39 PM
cd75bus
10-23-2008 07:21 AM
maro
03-10-2007 12:15 AM
Accord5726
10-25-2005 11:18 AM
Quick Reply: Smaller Size Tires
