no speedo
my speedo works every now and then and when its not working it stays at 20...what do i need to replace?
RE: no speedo
sounds like the speedo head. my 94 did that. you can either send it off to a speedo repair place (no swimsuit jokes, please), or get a new one....
RE: no speedo
thanks for the reply, and where do i find one of them?...and a buddy of mine said it could be the vehicle speed sensor? is that a possibility also?
RE: no speedo
wow, i just realized this is site help...im an idiot. anyway it can be moved to get more traffic?
RE: no speedo
i would guess its not the vss, cause your symptoms are identical to mine, but i beleive that if the cruise still works, its not the vss....but dont quote me on that.
RE: no speedo
The cruise only works if the speedo does.
RE: no speedo
i'd stll guess the speedo. anyone else?
RE: no speedo
ORIGINAL: 9accord5 The cruise only works if the speedo does. Cruise doesn't work when speedo doesn't work = VSS problem. Cruise works even when speedo is not working = speedo problem. On mine the cruise works even when the speedo doesn't, which means there is something wrong internaly with the speedo. That means I have to pull the speedo and send it to a speedo shop. |
RE: no speedo
oh, alright cool thanks guys.:)
RE: no speedo
i found em on ebay, do i need the one with the sensor andgear? or the just the sensor?
