tac problem
My takometer (speedometer) light keeps on turning off. do you guys know what seems to be the problem??!! pls need your help on this
RE: tac problem
ORIGINAL: WhItE cOrD My takometer (speedometer) light keeps on turning off. do you guys know what seems to be the problem??!! pls need your help on this you mean on the instrument cluster correct?? is it all the lites or if 1 lite only .. which one tachometer or speedometer ?? cause tach and speedo are 2 different gauges ,, tach is far left, speedo is in the center |
