98 accord catalitic converter
Would I be able to replace my cat with straight pipe and still run good
Please don't; the lungs of everybody around you will thank you.
You'll set a code without more work. Most states will fail you with an emmision code.
The real question is "why" do you want/think you need to do this? |
It is not advisable to remove the catalytic converter and install a straight pipe in its place. The engine was designed to run with a particular amount of back-pressure... removing the cat will alter/reduce the pressure
