cat and resonator delete
Old Jan 20, 2009 | 02:54 AM
pao2's Avatar
Default cat and resonator delete
Hi guys,
I have a 06 accord coupe v6 and I want to do cat and resonator delete because I want louder sound. Does anyone know whether it is gaining or losing HP? I'm afraid of losing horsepower. thank you very much.
Old Jan 20, 2009 | 07:18 AM
falkore24's Avatar
Default RE: cat and resonator delete
http://www.importtuner.com/features/...val/index.html
Read this article. If you want sound, change the piping and mufflers. If you want power, get a catback.
Old Jan 20, 2009 | 11:54 AM
pao2's Avatar
Oh, I see. Thank you. So, by removing the catback I will get bigger horsepower rather than the OEM cat, right?
Old Jan 20, 2009 | 12:34 PM
cjdm98's Avatar
A cat back exhaust bolts on after your OEM catalytic converter,Hence the name "Cat back".You can get an High flow cat,such as a magnaflow to get better flow.
Old Jan 20, 2009 | 12:55 PM
Good little post there...the things people go thru to get some sounds...ehhhh
Old Jan 20, 2009 | 01:05 PM
finch13's Avatar
Get a header, hi-flow cat, and catback/custom piping to get a louder sound...
Removing the cat is pointless and harms the environment. Removing the resonator will likely give you the raspies, a longer resonator (22"-28") will give you a deeper grumble.
Old Jan 20, 2009 | 01:30 PM
cjdm98's Avatar
ORIGINAL: finch13
Headers are out of the question for the OP accord.
Old Jan 20, 2009 | 01:34 PM
finch13's Avatar
ORIGINAL: cjdm98
ORIGINAL: finch13
Doh! [:@]
Old Jan 20, 2009 | 03:19 PM
falkore24's Avatar
I believe that there are upgraded J-pipes available ..... I think thats what they-re called ..... secondary header pipes ..... 2-1.
Old Jan 20, 2009 | 03:39 PM
finch13's Avatar
Um... isn't that called the downpipe?
