header wrap??
hey i have a stainless steel header and was wondering if i should wrap it.... i have a aem sri and the extra heat is prolly killen the inside temp.... should i wrap my header?????
RE: header wrap??
I would just to keep the temp in the engine bay down as much as possible
RE: header wrap??
DC Sports says warranty if void is header(s) are wrapped so be careful.
RE: header wrap??
ok ya i agree with live2rice but rtexasf has a good point i had heard that wrapping them can sometimes melt the header itself...(nascar cars did that when the where wrapped) but what else can i do to keep my engine temps down... ceramic might to expensive but this summer i was thinking bout getting a carbon fiber hood so should i go with a vented one and if i do sholud i build adapters for the winter so my engine doesnt get snow and stuff on it or should it be fine
RE: header wrap??
ORIGINAL: BuntinBoy9 ok ya i agree with live2rice but rtexasf has a good point i had heard that wrapping them can sometimes melt the header itself...(nascar cars did that when the where wrapped) but what else can i do to keep my engine temps down... ceramic might to expensive but this summer i was thinking bout getting a carbon fiber hood so should i go with a vented one and if i do sholud i build adapters for the winter so my engine doesnt get snow and stuff on it or should it be fine also i would switch back to stock hood in the winter |
RE: header wrap??
I am pretty sure header wraps cause SS headers to crack. Your SS headers should actually run cooler, b/c they do not have the same heat sink effect as your oem manifold. There is a reason why headers dont come w/ heat shields. They cool down waaaay more quickly than the stock one.
I had an ss header and had no problems w/ heat. I put the oem manifold on and still havent put the heat shield on. No problems. If anything, you can buy a wrap for your intake. |
RE: header wrap??
You can have your SS header ceramic coated or even powder coated with a ceramic type material.
RE: header wrap??
ORIGINAL: 19Accord97 I am pretty sure header wraps cause SS headers to crack. Your SS headers should actually run cooler, b/c they do not have the same heat sink effect as your oem manifold. There is a reason why headers dont come w/ heat shields. They cool down waaaay more quickly than the stock one. I had an ss header and had no problems w/ heat. I put the oem manifold on and still havent put the heat shield on. No problems. If anything, you can buy a wrap for your intake. |
RE: header wrap??
Fiberglass deteriorates over time and looks like cr@p when it falls apart. If you do want to wrap them, I'd get the jacket type of cover instead of the wrap. IMO, it's not worth it.
RE: header wrap??
hey! don't trash the fiber glass wrap! i have my down pipe wrap in that! i did my downpipe w/ a thick tube...it looks better wraped... believe me, my welding skills are ok...but not in an artistic manner
