Modification Support
Hi All,
I have a 2007 Honda Accord EX Coupe, 4Cyl VTEC, K24A8. I've already purchased/installed a K&N Intake, DC Headers(4-2-1) and A'pexi exhaust with cat. I have my next modifications lined up, but wanted to know if anyone had superior knowledge of this engine type and if it is capable to put out noticeable numbers. The mods I am looking at are: Throttle Body (75mm) Skunk2 Pro-Intake Manifold Kelford272 Cams (Upgrade Valve Springs and new Retainer) Would these upgrades with the right tune increase 45hp/35lb ft+ or would this be a big waste of money for this car/engine? Thank you for any suggestions. |
Anyone have any suggestions on this matter?
Thanks! |
The intake and throttle body wont make too much of a difference without the cams. But all 3 should add a decent amount of power, idk about 45hp without a port job on the head. Especially not whp. Have you looked into k20a2/k24a2 head swaps?
I'm thinking with all the money it would cost to make the changes the OP is talking about it might be cheaper to do a turbo applicaiton and call it a day; comparable price, lots more power.
Have not looked into a head swap but it is an interesting route. I may just get the original head ported and polished and get the three upgrades. Should give some pretty significant gains I would imagine.
If I ported the block would I need to look at upgrading other engine internals outside of the cams/headstuds? Thank you, |
Ported the block? Do you mean head? You will definitely need kpro and a new tune to maximize the gains from that.
you will not see a " great " amount of power after upgrading anything. the best thing u can do is add a turbo or super charger for maximum hp.... upgrading ur cams will benefit be the best upgrade though, since u already have ur intake/exhaust done. I just hope that ur diameter for ur intake/outake match and arnt more then .25' over stock, otherwise ur losing power.
*YOU will want to get this tuned by a pro..see if there is a tuning shop near by you. |
(Post 308361)
