Power from a F22B2
I've been thinking about beefing up my car's power alittle more. I'm asking if it would be a benefit to put on a slightly larger throttle body.
Just on a side note.....I did this on my 1998 Dodge Ram 1500 with a Fastman throttle body 52mm; stock was 48mm. And I got a crispier response and better towing benefit. |
If you want power, don't just swap the tb.....you can also do an F23 intake manifold swap. you supposedly get pretty good gains off that.
thanks man, I'll look into it
I have a f22a did a tune up new NGK wires and plugs, all the basics. I put a cold air on it and noticed a huge difference. Then I put a full exhaust on it and the difference was amazing. I could break the tire loose at will. Which is nice when your in an accord haha : P I had to eventually take the headers off because it was too loud and my neighbors bitched too much, but if your looking for quick cheap power I'd suggest going that route.
You can find a cold air on e-bay for like 30 bucks that works just fine |
Sorry I meant an F22B2 not a f22a
Thanks
Originally Posted by carbonfiber89
(Post 321533)
You can find a cold air on e-bay for like 30 bucks that works just fine *Thank you for responding.* I thought I might be able to add additional hp/tq. I don't want to fool around with a header. Bad luck with past projects. Thought a throttle body would be my next thing on the list? |
Originally Posted by hondafreak91c
(Post 321334)
The F23 intake will help. Any decent power will come with the addition of an upgraded cam shaft. Check out bisimoto for those.
Just noticed your at Ft Bragg, that's where I am too. |
Live2rice, you live in Fayetteville, your from NH and you like the boston bruins. You are just like my room mate. But he hates when people mod their cars? Go figure.
An intake would be radical, cam would be the best thing since sliced cheesed [lack of a better word]. I would have to let a pro tackle those. Not this guy. |
Sounds like a good guy lol.
If you haven't replaced your timing belt lately that'd be a good time to do the can since all that would be off already. |
