06 Honda Accord 6cyl. automatic trans
Tranni issue... My left front axel went out and I had it replaced, since I got my car back only when I turn a sharp corner the tranni will slip briefly... What could be causing this?? Done help please.. I checked the fluid and its where it should be.
When the original axle failed, how hard did you push the transmission before you figured out what was wrong?
If the inner CV shaft is not positively engaged, slippage might occur in a sharp turn. Return to shop or check engagement yourself. It should connect w/ a audible click.
good luck |
Originally Posted by shipo
(Post 379473)
